Author Topic: Servo Tester  (Read 5062 times)
Servo Tester
« on: March 03, 2010, 16:56:47 PM »
Ever stuck a servo in somewhere inaccessible, hooked everything up and found the servo doesn't work? This little device helps prevent that. Hook the servo up and it runs the servo through it's ful range at varying speeds until you disconnect it. No more failed servo's epoxied in!! Penies to make with the programmed pic at £2.50 posted from the guy in the article. Mine arrived in less than 24 hrs and took under 15 minutes to make
http://www.rcmf.co.uk/4um/index.php?page=110
[youtube]http://www.youtube.com/v/_bL9ldd35O0[/youtube]
The actual device is the little lump just above the Y in Youtube, bottom right corner!
