I have been experiencing a new glue I found to the local DIY.
The glue is from Evo-Stick, and it's called "Serious Stuff Ultra" and they sell that in a cartridge format (need a cartridge gun...)
Anyway, not sure if that is already used by modelers, but this stuff is simply great !
I use to glue my servos in the wings using silicone, so I tried this glue for the ASW15...
Amazing !
The glue just grab the servo instantly ! Put a big bunch of glue, like I do with Silicone, and that dry in less than 24 hours, but you can already play with the servo (for setup etc etc) after roughly 30 minutes or so...
And impossible to move the servo, or unglue it once set !
But! Like Silicone, once set, it's a bit rubbery, slightly harder than silicone, and can be cut with a knife (good to remove the servo for maintenance if needed, but of course, you need to roll the servo in tape or heatshrink tube prior to gluing!)
I also tried it to glue servos inside a Fibre-Glass fuselage (a good drop, and the "flat" servo glue to the curve of the fuselage.. No frame needed!)... Also glued a servo tray in a FG fuselage...Works great, and same, impossible to unglue once set ! This is also an "Impact" glue, so because it is rubbery, at impact, the joint between the pieces move with the impact...
That thing glue pretty much everything to anything !
Did a few tests with wood etc etc, and can't fault the glue !
I don't know if that can be use to replace Silicone hinges (this is slightly harder than Silicone when dry...) but I'll try on a wing and let you know the result. I'm sure that will work, but that need to be tested in time...
