Author Topic: What about this ??  (Read 28805 times)
What about this ??
« Reply #30 on: July 22, 2009, 12:48:08 PM »
Bill wrote:
Quote
but "maybe" = absolutely no fecking chance!!.
You know my wife Bill?
No, I know my Ex-wife!!! :(  :cry:
What about this ??
« Reply #31 on: July 22, 2009, 13:01:42 PM »
Yes Keith. Flaps and ailerons are the way to go. For my flapped machines I just have a switch to mix flaps and ailerons together. Quadra flap some people call it. Then for landing I switch back to normal mode and use crow.
BTW what radio are you going for?? Futaba...??
See if it has flight modes? Very handy for changing camber. Just flick a switch and your ailerons and flaps droop a few mm. Good for light conditions or gaining altitude fast. Lots of 3D gliders recommend chamber changing. Brian you use this a bit?? Works well on the Voltij?
Don't have a wife  :wink:
What about this ??
« Reply #32 on: July 22, 2009, 13:17:34 PM »
Joe said:
Quote
Don't have a wife
And you still get no nookie?? (Oh well, at least you've got a right hand, :lol: :oops:  )........but this is way off topic. Let's return to servility
The type of Tx I'm getting is the Futaba, (has to be that brand because all my rx's are 2.4 Ghz FASST) model 10CG. It's got 12 programes dedicated for gliding, so I think it'll have what I need.
When are we gonna get this CNC machine up and running Joe? I want to get some of these ideas converted into actual planes :D
Nookie or not, let's go flying :P  !
Brian
What about this ??
« Reply #33 on: July 22, 2009, 18:48:29 PM »
.Joe Keith,
Yes 4 axis = camber changing.
You set it up in a flight mode so that the throttle stick is the camber adjust.
Mid throtle = no camber
Low throttle = +ve camber 3 to 5 mm, proportional from mid to low stick.
High throtlte = -ve camber 3 - 5 mm.
This gives a symmetrical wing a big advantage over a semi when inverted and just about as good upright.
In another mode the throttle opperates the crow.
In another flaps and ailerons are all set as ailerons with the wing section restored.
Brian
Serious Power
What about this ??
« Reply #34 on: July 22, 2009, 19:59:42 PM »
Yes Brian, I have a pretty good idea of what you mean. :)
Question: When using the throttle stick in the way you describe, would I have to remove the ratchet and arrange the throttle stick to have springs to center it when there is no fingure pressure on it. ie so both sticks are self centering?
I'm wondering if the throttle stick isn't self centering how would I know when there is zero camber on the wing? :?:
Brian
What about this ??
« Reply #35 on: July 22, 2009, 20:45:22 PM »
Keith,
Good question.
My solution was to leave it as a ratchet but I put a big notch at the centre point so it clicks heavy on centre.
Brian
Serious Power
What about this ??
« Reply #36 on: July 22, 2009, 21:59:48 PM »
Quote from: "Brian"
Keith,
Good question.
My solution was to leave it as a ratchet but I put a bog notch at the centre point so it clicks heavy on centre.
Brian
Only the Irish could have a "bog" notch! :wink:  :shock:
(Belfast address, but born and brought up in Scotland) :lol:
What about this ??
« Reply #37 on: July 23, 2009, 06:06:45 AM »
Quote
Well,..................nobody's perfect :lol:
What about this ??
« Reply #38 on: July 23, 2009, 19:09:21 PM »
proof it's not always tidy in my workshop :oops:  :oops:
yesterday @ 1630
What about this ??
« Reply #39 on: August 08, 2009, 00:24:52 AM »
Joe,
If you ever get the cnc foamcutter up and running, what about a few of these for a one design aerobatics comp?
http://eppconcept.free.fr/MiniToons.php
cnc cutting sections are a free download
What about this ??
« Reply #40 on: August 08, 2009, 07:58:26 AM »
Hiya Bill.
Making good progress with the CNC machine. Just getting it all calibrated at the moment. Had/have a few problems with the card. The cores look pretty good so far though.
Yeah, have the files for the Minitoons somewhere. Think I have the files for version 2 which is basically the Wasabi. Same size, same profile. Should be a fun little aerobat!
Will be ordering EPP very soon. Let me know if you want some.
J
What about this ??
« Reply #41 on: August 08, 2009, 18:26:37 PM »
I'd love some EPP Joe. it's paying for it that's the problem :(
Won't have money to buy much until after the civil case for the accident.(Oct/Nov)
Acrobatic schedule
« Reply #42 on: November 27, 2009, 16:35:58 PM »
Found a posting on an aerobatic comp in South Africa. Basic schedule which looks like we could adapt it for our purposes;
http://mgasa.blogspot.com/2009/02/two-oceans-slope-soarers-aerobatic.html
http://www.toss.co.za/documents/Slope%20Aerobatics%20Manoeuvres.pdf
