Author Topic: Build attempt / learning process  (Read 20839 times)
Joyplanes
    • Joyplanes RC
Re: Build Log
« Reply #45 on: July 20, 2021, 17:32:39 PM »
It's definitely for the slope.
This is all a bit new to me, technique and materials so it is not perfect, but highly enjoyable.
I started by cutting out the fuselage profiles and then using a hotwire to get the rough shape. I then drilled some rods into either end to add strength and make a sort of rotisserie arrangement for later. Filed the rough shape further and then sanded.
That's a nice built, where do you get that foam?
AndyB
Re: Build attempt / learning process
« Reply #46 on: July 20, 2021, 21:46:50 PM »
I actually got it from a neighbour who was have exterior insulation installed. It was 300mm closed cell styrofoam and was stronger than others I tried. for example, it resisted me poking my finger at it where other foams seemed to compress and collapse. I don't know if it's the best stuff to use, but it was free and worked well for me.
« Reply #47 on: July 21, 2021, 10:40:44 AM »
Andy,
  looks great, cannot wait to see it flying on the hills.
R
AndyB
« Reply #48 on: July 21, 2021, 11:01:08 AM »
I've got Mt Leinster for the 28/29 in the calendar, see you then
