Author Topic: 1/3 scale Grunau Baby IIb  (Read 48426 times)
Nhalyn
  • Where is gone my thermal ?
Re: 1/3 scale Grunau Baby IIb
« Reply #15 on: January 10, 2017, 09:18:15 AM »
Wow ! I like that !  :-*
« Reply #16 on: January 11, 2017, 00:47:16 AM »
Looking good!   8)
« Reply #17 on: January 11, 2017, 05:59:39 AM »
Wahou
Pense à ma vu de dessus du fuseau  8)
« Reply #18 on: January 11, 2017, 09:47:16 AM »
Thanks all :)
« Reply #19 on: January 22, 2017, 18:34:37 PM »
Very little time at home this week  :'( but I managed an hour in the workshop today!  :) Moved a bit forward on the Grunau.
Rudder: Sheeted and stained. I usually use "teak" varnish, but this time, I went for something lighter, and I really like it! Varnish is "Antic Pine".
Rudder horns are in steel, that I have for years in a box. Happy with them, they do look nice! And solid!
Waiting for it to dry, and I can cover it.
Nose: I went with a balsa block. The sheeting will them go over. I usually do it "hollow", but I wanted to try it this way.
I made the tow hook, very classic with a 10mm Aluminium tube with a piece of piano wore going through. Epoxied on the block, itself epoxied on the first former. Just need to sans in shape after that.
Battery shelf done also.
Fine sheeting started, so as the canopy area.
Hopefully, more progresses next week!
Sorry for the dark photos, did not paid attention when I took them :(
« Reply #20 on: January 27, 2017, 11:17:43 AM »
Sllooowwwwlllyyyy....
« Reply #21 on: January 31, 2017, 14:10:46 PM »
J arrive pas à imprimer à la bonne échelle  >:(
JG
    • http://www.silent-flight-forums.co.uk
« Reply #22 on: March 07, 2017, 16:58:34 PM »
Hello Fred  8)
I have a couple of questions on this build which i am sure you will answer, but
1) how are you going to keep the wings together on the fuselage ?
2) how is the elevator servo and elevator horn going to go ?
I renovated 1:3 scale 1 of this a year or 2 ago  ;)
Thanks JG
« Reply #23 on: March 10, 2017, 09:27:04 AM »
Hi JG,
To answer your questions:
1> Good old hooks and rubber band :) On the GB, there is a metal plate that cover the fuselage/wings, so it's all hidden. I keep it practical in this area rather than purely scale, especially when you don't se it :)
2> Elevator servo will be positioned under the stabilisator. To connect the elevator horn to the clevis, I will use the same as the real one, and use the hatch on the side of the fuselage. Same as the wings, practicality over scale. Everything is hidden of course, and very easy to connect, and also to maintain.
Saying that, my first plan was to put the servo in the stab, in the middle, but the space is a tad too small for a decent servo (not wide enough).
Hope this helps
« Reply #24 on: March 10, 2017, 12:59:01 PM »
Et hop
JG
« Reply #25 on: March 12, 2017, 14:34:14 PM »
Fred - I knew you would have it sorted  ;) what is the wing span ?
Thanks JG
« Reply #26 on: March 20, 2017, 11:53:06 AM »
WS is 4.6m (1/3 scale :) )
Alright, time for an update!
Received my sheetings! So I started on the wings.
Not much work at this stage. Spars are my usual 8x8mm x2, and all the sub assembly are glued first, like the airbrakes box, servo supports etc etc.
Then, all that is glued on the top spar, upside down as usual.
Bottom spar is glued, so as all the ribs, so photos tonight of this stage! Left to do: False LE after setting the first rib to the correct angle, glue the TE, wing joiner tubes.
And I'll start to have a look at the airbrakes now.
« Reply #27 on: August 10, 2017, 08:01:59 AM »
Alright, so, after a looonnnggg break on the Grunau, back to it!
Servo trays are glued in place. Elevator servo is under the elevator.
Sheeting of the fuselage has started. All done in 0.6mm plywood, and I am using the same method as my Ka1. It's long and painful (you do twice the work), but I kind of like it, as everything then fits perfectly without any fuss and you do proper wood management also :) (thin plywood is not cheap!)
Rudder has been covered, and already received a coat of varnish. I went with a slightly lighter color, and should be more vibrant once I put 5 of 6 coats of clear on it. Well, that's the plan, works in my head anyway :)
« Reply #28 on: August 10, 2017, 19:15:18 PM »
Wahou  bon ça vole quand  8)
« Reply #29 on: August 13, 2017, 14:55:49 PM »
Demain :) Nnaaannnn, Falaise hopefully!
