Author Topic: Set of wings  (Read 7359 times)
Set of wings
« on: May 28, 2014, 23:26:08 PM »
I'm working on an idea and want a set of wings if you have any that are minus a fuse and need a home, the cord needs to be between 160mm and 250mm and overall span 2m plus. Balsa build up wing or foam core
Covered or not covered doesn't matter but in ok repair, I don't mind some superficial damage but no warping or bags on kindling either. Thanks
Stephen[/i]
Set of wings
« Reply #1 on: May 29, 2014, 15:52:01 PM »
Here you are then,…
Each wing half has a root chord of 250mm, a thickness of 28mm, and a length of 1250mm.
As you can see they are full house wings but without any servos. I’ve no idea what they are off of or their airfoil. They’re built up construction &  have been hanging around in my garage for years. They seem straight enough, although not perfect. :wink:
Little Keith
Set of wings
« Reply #2 on: May 29, 2014, 15:55:44 PM »
You're a little diamond Keith, thanks
Stephen
Set of wings
« Reply #3 on: May 29, 2014, 15:58:17 PM »
Wwooooo, hold your horses Stephen,…I haven’t told you the price of ’em yet! :twisted:
