Author Topic: Sell Balsa Wood  (Read 7688 times)
balsaindo
Sell Balsa Wood
« on: July 02, 2008, 19:51:55 PM »
Our company located in Lampung in Indonesia.
We have resource of Balsa wood in our region and now we want to continue planting it so it could be available continually.
We can supply balsa wood any size and good quality.
Balsa Block
Thickness  Width        Length
60mm       101mm        1200mm   USD580/CBM
60mm       101mm        1020mm   USD530/CBM
60mm       101mm         930mm   USD490/CBM
60mm       101mm         780mm   USD420/CBM
60mm       101mm         630mm   USD390/CBM
60mm       107mm        1200mm   USD600/CBM
60mm       107mm        1020mm   USD535/CBM
60mm       107mm         930mm   USD495/CBM
60mm       107mm         780mm   USD425/CBM
60mm       107mm         630mm   USD395/CBM
Balsa Sheet
Width       Length   Thickness
10cm        100cm      1 mm  = USD0.15/sheet
10cm        100cm      1.5mm = USD0.15/sheet
10cm        100cm      2 mm  = USD0.20/sheet
10cm        100cm      2.5mm = USD0.25/sheet
10cm        100cm      3 mm  = USD0.30/sheet
10cm        100cm      4 mm  = USD0.35/sheet
10cm        100cm      5 mm  = USD0.40/sheet
10cm        100cm      6 mm  = USD0.45/sheet
10cm        100cm      7 mm  = USD0.50/sheet
10cm        100cm      8 mm  = USD0.55/sheet
10cm        100cm      9 mm  = USD0.60/sheet
10cm        100cm      10mm  = USD0.60/sheet
2)Dowel
length  diameter:
100cm       2mm  = USD0.02/sheet
100cm       3mm  = USD0.03/sheet
100cm       4mm  = USD0.03/sheet
100cm       5mm  = USD0.04/sheet
100cm       6mm  = USD0.05/sheet
100cm       7mm  = USD0.06/sheet
100cm       8mm  = USD0.07/sheet
100cm       9mm  = USD0.08/sheet
100cm       10mm = USD0.09/sheet
100cm       15mm = USD0.1/sheet
3)Sticks
2mm         2mm       100cm = USD0.01/sheet
3mm         3mm       100cm = USD0.02/sheet
4mm         4mm       100cm = USD0.03/sheet
5mm         5mm       100cm = USD0.04/sheet
6mm         6mm       100cm = USD0.05/sheet
Density : 130kg/CBM.
Sell Balsa Wood
« Reply #1 on: July 03, 2008, 12:12:15 PM »
What is the MOQ for balsa sheets ?
Can you have A - B - C Grain ?
Shipping to Ireland for a CBM ?
Thanks
balsaindo
Minimum Order Quantity
« Reply #2 on: July 03, 2008, 16:37:21 PM »
MOQ = 1000 Sheet for sheet.
MOQ =     15CBM for Balsa Blocks.
Shipping Cost = 130USD/CBM.
Thank You,
Joseph Siswanto.
