Author Topic: For Sale - CNC Router - SOLD  (Read 8843 times)
« on: January 11, 2013, 12:49:39 PM »
Need more room!
So the router have to go!
This is my cnc router.
Cutting size is about 70cm x 40cm (but size can of course be increased (only found 1m long steel base at the time  :(  you can buy 2m long ones now!)
Comes with everything except : Router (I keep my Kress!) and PC / Software, although, if you are stuck for a PC, I can give you one!)
Card is a CNC3AX (Careful now, if you plan to salvage the machine for a foam cutting machine, this card only do 3 axes!)
I fired it up sometimes last year, but I will check the machine again before selling it, but expect to have to check the machine rigidity again to make sure (anyway, if we move the machine from the table, rigidity will need to be re-checked anyway).
Machine is belt driven.
I will leave the power supply with it (12v for the card and a PC power supply for the fan for the Z axis)
I ran this machine using NINOS, but these days, you have lots of softawres available, some free, some not. Card is for LPT port (but a module can be added for USB support)
Comes will all my router's bits, from 3mm to 0.8mm. Lots of them  :D
Machine build log : http://gliderireland.modelisme.com/cnc.htm
200€
