Author Topic: Where to buy Balsa, spruce, ply etc.  (Read 27147 times)
« Reply #15 on: June 09, 2008, 12:40:36 PM »
I didn't knew you dealed with the site! :) If not i would contact you at first place.
Yes i understand the 10pc thing.
Part of this stuff is for the glider, last time i went to PT i bought some film there and i also got some servos. They are a bit big in heigh so that is the need for some ply to raise the mount were they go.
And also because i managed to fit my GP Reflections shockflyer in the bag, and i now need to do a firewall for the motor. :) Some 3 or 4mm ply needed.
The balsa is to repair some parts i noticed that were broken in the wing when i removed the cover film. I think it's 1.5 or 2mm balsa.
Thanks!
Nando
« Reply #16 on: June 09, 2008, 13:49:09 PM »
Well, if you don't need a lot, I have bits and pieces of 3mm plywood and 2mm balsa in my garage !
Next time we meet, just remind me, and I'll bring a bunch for you !
balsaindo
Balsa Wood
« Reply #17 on: September 08, 2008, 21:30:12 PM »
Our company can supply balsa wood.
please visit our company website at www.balsaindo.com
Balsa Block
Thickness Width Length
100mm 100mm 1000mm USD 520/CBM
60mm 101mm 1200mm USD500/CBM
60mm 101mm 1020mm USD490/CBM
60mm 101mm 930mm USD470/CBM
60mm 101mm 780mm USD420/CBM
60mm 101mm 630mm USD390/CBM
60mm 107mm 1200mm USD501/CBM
60mm 107mm 1020mm USD495/CBM
60mm 107mm 930mm USD4475/CBM
60mm 107mm 780mm USD425/CBM
60mm 107mm 630mm USD395/CBM
Balsa Sheet
Width Length Thickness
10cm 100cm 1 mm = USD0.15/sheet
10cm 100cm 1.5mm = USD0.15/sheet
10cm 100cm 2 mm = USD0.20/sheet
10cm 100cm 2.5mm = USD0.25/sheet
10cm 100cm 3 mm = USD0.30/sheet
10cm 100cm 4 mm = USD0.35/sheet
10cm 100cm 5 mm = USD0.40/sheet
10cm 100cm 6 mm = USD0.45/sheet
10cm 100cm 7 mm = USD0.50/sheet
10cm 100cm 8 mm = USD0.55/sheet
10cm 100cm 9 mm = USD0.60/sheet
10cm 100cm 10mm = USD0.60/sheet
2)Dowel
length diameter:
100cm 2mm = USD0.02/sheet
100cm 3mm = USD0.03/sheet
100cm 4mm = USD0.03/sheet
100cm 5mm = USD0.04/sheet
100cm 6mm = USD0.05/sheet
100cm 7mm = USD0.06/sheet
100cm 8mm = USD0.07/sheet
100cm 9mm = USD0.08/sheet
100cm 10mm = USD0.09/sheet
100cm 15mm = USD0.1/sheet
3)Sticks
2mm 2mm 100cm = USD0.01/sheet
3mm 3mm 100cm = USD0.02/sheet
4mm 4mm 100cm = USD0.03/sheet
5mm 5mm 100cm = USD0.04/sheet
6mm 6mm 100cm = USD0.05/sheet
Density : 130kg/CBM.
Minimum order for each size is 1000 pcs.
