Slow Down!!
Very good start Andrew! :clap:
And I must add, without plan! :clap:
For the bellcrank, you should have 2 or 4 rounds in wood, to re-inforce where the rods are going(if you see what I mean!)
If not, glue some metal ones (the one for small screws), that will do the job.
Also, but you certainly already know that, install the elevator servo and bellcrank before doing the bottom sheeting!
Oh and the piece T1 (where the rudder is glued to if I remember) might be not wide enough!
Doesn't matter, as all that will be sanded round! (That's because I changed my mind about the way to cut the balsa strips at the end of the fuselage half way through! #-o
Anyway, good stuff, looking good! :clap: :clap:
