Author Topic: Quark 2M - Back to cutting innocent trees!  (Read 832591 times)
DannyChapman
Re: Quark 2M - Back to cutting innocent trees!
« Reply #465 on: March 08, 2017, 21:56:40 PM »
Thanks - yes, I was planning on doing that anyway (possibly making a hinge with rod & tube, so long as I have enough). But my concer was that the tip of the fuselage is supported by not that much fuselage - just the section underneath the curved slot. It twists more easily than I would like.
I'm actually in the process of sheeting the fin (I have some nice 1/32" sheet from long long ago) with the grain running vertically. Hopefully that should stiffen up the bottom of the fin, and therefore reduce the twistability...
« Reply #466 on: March 09, 2017, 00:38:13 AM »
Hey Danny, I sheeted the fin with 1/32 and with the rod it's plenty strong. It's a slow flyer anyway so not much stress. I just plug in the elevators which are a bit stiff and they hold ok only move out on landing. If they're loose rub a bit of impact adhesive on the rod to give a bit of grip.
DannyChapman
« Reply #467 on: March 09, 2017, 01:12:14 AM »
I had just sheeted the fin with 1/32, dry fitted it, and liked the improvement, when I saw your post - so all is good. With the rod as well it should be fine. Thanks for the info about the elevators too.
Nhalyn
  • Where is gone my thermal ?
« Reply #468 on: March 09, 2017, 12:36:48 PM »
Rudder should be sheeted ? I've not done on mine...  :-[
I've add carbon plate 3x1mm at the rear end of the rudder for the full height and also a small part in the rudder leading edge at the basis. Seems enough strong for me.
« Reply #469 on: March 10, 2017, 09:19:10 AM »
Hi Danny, welcome here :)
Sorry, I'm coming after the battle, but no reports of any rudder issues.
Like John, (but without the block) I glued a 4mm carbone tube along the rudder. Landed a few times on the back (ooppss!) and never broke anything :)
I was also thinking making the rudder removable, and use the 4mm tube as the hinge... But never did it.
As far as I know, very few people, if any, sheeted the rudder. Once covered, it's much stronger. but no arm in doing it anyway! :)
Nhalyn
« Reply #470 on: March 13, 2017, 10:21:48 AM »
Hi guys !
Some news from the battlefield...
Here is a ready to fly fuse... And believe me, this box contains a full pair of wing...  :-[
Well, with a little touch of glue, looks better...
Note that I've add some cross ribs Inside the ailerons and now they are perfectly torsion rigid for nothing more in weight. Perfect for high rools rates !
Right wing is now ready for sanding and covering.
DannyChapman
« Reply #471 on: March 13, 2017, 11:32:38 AM »
That looks good. I think I may adopt your cross-bracing on the ailerons.
I have a numpty question - what do people use/favour for covering? Oracover/Profilm or Solarfilm? Is Oralight too, well, light? Do I need to treat the wood before covering or will that just add unnecessary weight?
The last wood glider I made was a Phase 6 (still going strong, fibreglassed), and before that either tissue or nylon & dope planes. I'm a bit behind the times...
Nhalyn
« Reply #472 on: March 13, 2017, 13:10:10 PM »
Mine is covered with oracover without threatment, not neccessary.
Oralight is lighter but also more fragile.
Solarfilm is still good...
Nhalyn
« Reply #473 on: March 14, 2017, 12:39:29 PM »
What looks likes a left wing inside ?
« Reply #474 on: March 14, 2017, 21:19:26 PM »
Hi Danny,
Mine was covered with the cheapo hobbyking semi transparent covering. Worked well.
Otherwise, same as Nhalyn, Oracover or solar are good choices  :)
Nhalyn
« Reply #475 on: March 22, 2017, 09:01:51 AM »
some news ?
It's finished !
(Well, need to create control horn and command for ailerons, and setting center of gravity, but that's all, folks...)
Is it yellow cub or yellow duck ?
QUARK !!!  8) :)
DannyChapman
« Reply #476 on: March 25, 2017, 22:31:42 PM »
I'm getting there!
« Reply #477 on: March 26, 2017, 08:48:25 AM »
These 2 Quarks are coming along nicely! 8)
Nhalyn
« Reply #478 on: March 27, 2017, 11:20:29 AM »
Good !
Mine is fully sheeted on the wings.
Final weight is 1.6kg ready to fly.
I need a slope, urgently... ::)
« Reply #479 on: March 27, 2017, 11:49:31 AM »
Maybe monday 8)
