Author Topic: Connecting wing servos en-mass  (Read 18713 times)
« Reply #15 on: July 19, 2010, 20:34:59 PM »
I would have to agree with Fred. Those green plugs are a pain to solder strongly. I had two on my K8 and the connections kept on breaking so I had to change them.
« Reply #16 on: July 19, 2010, 21:36:44 PM »
By the way, forgot about the 5 flat pins from MPX !  :oops:
Slightly easier to solder than the green ones in my opinion
Shame, we have loads of them in stock here  :oops:
« Reply #17 on: July 19, 2010, 21:51:44 PM »
Doohhhhhh!
« Reply #18 on: July 19, 2010, 22:24:05 PM »
with the 6 pin multiplex plugs, once I'm sure all works OK, I pot the wires in epoxy to take the strain off the wire/solder joint
« Reply #19 on: July 20, 2010, 05:52:36 AM »
Now that’s a good idea Bill. :)  I'd been trying to imagine some way of securing the outer insulation of the wires to reduce the physical stress on the electrical joints.
Your idea also reduces the possibility of corrosion on the joint as well.
Well done Bill :clap:
