Alright, weekend, big push
Covering done.
Subject chosen
Now, time to piece everything together so we have what's look like a plane
First, the subject. It is an Aero Commander 500 from a company called "Pan Adrian" in Croatia. Now the national company I believe.
It was between this one, or one from the Argentinian Air Force.
Anyway, that one did fit the bill in simplicity for a quick job
So, all covered in white film. Rudder in Red vinyl. Once fuselage covered, the root ribs are glued and edges covered to hide the wood. At this stage, the wing joiner tube are glued also.
Then, vinyl is cut
And applied following the photos.
I added my panel lines using my usual 1mm vinyl tape. Less is more, and it does enhance the plane big time. Small things...
