Author Topic: Has anyone built one of these kits.  (Read 4335 times)
ASW22
« on: April 13, 2014, 00:11:30 AM »
Hi all.
I picked this up within the last two years and I have been tipping away at it ( from time to time ). Has anyone out there build & flown one and if yes What do you think of this kit/model.
Adrian.
ASW22
PS:
« Reply #1 on: April 13, 2014, 00:13:51 AM »
Krick Grunau Baby llb
from Krick
1/6 Scale Vintage Glider Kit
Wing span (89in) 2262mm - Length (40in) 1015mm - Wing Area (611.3sq.in) 39.44sq.dm - Weight (2.75-3lb) 1.3kg - Radio required 3-4 channel
The Granau Baby was developed in 1932 from an earlier design of Edmund Schneider and Wolf Hirth. Its performance and flying characteristics, together with its construction methods, soon made it the most popular secondary training glider in Germany.
Included are die-cut and pre-shaped parts, an ample supply of top quality sheet and strip-wood, full accessory content with control linkages, hinges, metal fittings, windshield, cockpit coaming, multi-sheet transfers, full size plans and comprehensive building instructions.
