Author Topic: Quark 2M - Back to cutting innocent trees!  (Read 429436 times)
« Reply #285 on: July 02, 2012, 09:12:48 AM »
Hello
I receive for my wedding a short kit of Quark . The building start as soon as possible. :D
« Reply #286 on: July 02, 2012, 09:33:52 AM »
Congratulations on you recent marriage. The pictures looked like you had a wonderful day. I am wondering what you new wife got if you got a new airplane? :D
Maybe the may hours of peace and quiet while you are building it.
Best wishes Ralph
alibodin
« Reply #287 on: July 03, 2012, 22:33:39 PM »
Back to work this week so less time to build :(
Added a frame around the servo plate and sanded it down so the servo plate was a nice snug fit.
Repeat for other plate. Cut some wood and glued to plate for servos to mount on to.
Ailerons next!
Alistair
« Reply #288 on: July 04, 2012, 08:14:31 AM »
Again really nice work Alistair, I noticed Fred's Quark had his aileron servo mounted on the actual servo cover plate.
He had an aileron servo failure when I flew with him on Mt Leinster and he had the servo changed in a matter of minutes. I thought it was a great idea especially if your landing site has a rough landing area.
alibodin
« Reply #289 on: July 04, 2012, 18:03:11 PM »
Richard thank you again for the encouragement. I will indeed have my servos on the plate as per this picture.
Will add some fibre glass and epoxy to strenthen the wood on the plates.
Alistair
GeorgeB
    • http://bionic-george.blogspot.com/
« Reply #290 on: July 05, 2012, 09:43:52 AM »
Hallo again from Prague, I'm sorry for no posting, but almost no time for building. Anyway there is a small progress
And I have a question:
 What is a shape the ends(tips ?) of wings, I mean from front view.
Plese show me it on photos.
Thank you.
George
GeorgeB
« Reply #291 on: July 05, 2012, 15:48:22 PM »
Another question, the control horn on aileron is attached just to balsa 1,5mm plate or there in the place is something harder what hold the horn?
Thank you.
G
alibodin
« Reply #292 on: July 05, 2012, 18:01:23 PM »
G,
Your Quark is looking good.
I am about to do my horn and will take pictures later. The horn will be 1.5mm ply and glued to the aileron spar and top sheet at the front of the aileron. I will then add block balsa either side glued to the horn, top aileron sheet and leading edge of aileron. Finally I will add the front sheeting either side of the horn.
Here is a picture that hopeully clarifies what I am doing.
Hope it helps.
Alistair
GeorgeB
« Reply #293 on: July 05, 2012, 20:26:45 PM »
Quote from: "alibodin"
G,
Hope it helps.
Alistair
Thanks a lot Alistair, I'll do it same way!
And about the shape of wings tips?
George
alibodin
« Reply #294 on: July 05, 2012, 22:03:29 PM »
Here is the completed aileron horn.
Need to add cap strips to aileron.
I have yet to do my wing tips. From pictures I have seen they are not shaped as they are flat at end of wing. There may be a little rounding of the leading edge at the wing tip.
I actually plan to add wing tips so as to protect the aileron for the ocassional cartwheel landing I do. :) Also some protection for transporting as well.
Alistair
alibodin
« Reply #295 on: July 06, 2012, 20:59:01 PM »
Well I have done the starboard aileron.
On with the port aileron.
Questions if I may.
1) Centre of Gravity. On the plan it is 5mm in front of the front spar. Is that a good starting point or an ideal? I want to balance the model with lead in the nose at the most rear COG before covering, then add some easily removeable lead for first few flights.
2) What is the angle for the tailplane relative to the wing for the initial setup??
Alistair
alibodin
« Reply #296 on: July 07, 2012, 15:20:37 PM »
Building nearly completed. Rigged it all up to see how much lead to roughly balance at rear COG. Seems I need 70grams to balance it. So this will be burried in the nose.
Need to add the nose with the lead, then shape the fuz, leading edge of wings, fin and rudder.
Then cover it all.
Alistair
« Reply #297 on: July 07, 2012, 15:35:05 PM »
Hi Alistair,
quick explanation: Fred & Richard are both at events, which is why neither has come back to you
alibodin
« Reply #298 on: July 07, 2012, 22:36:38 PM »
Thanks Bill,
No rush.
Added lead in nose.
Then took the razor plane and sandpaper to the fuz to round it off.
Makes a bit of a mess :)
Glad I ahve the garage to do this in.
Alistair
alibodin
« Reply #299 on: July 08, 2012, 19:01:04 PM »
Well my Quark is now ready for covering, shaped and nose added as well.
Covering ordered and should be here soon.
Final sand down with smooth and ready to cover.
Weighed it and came in at 1281 grams.
Alistair
